Interior Rendering - blue grainy floors
6 REPLIES 6
500 Views, 6 Replies
Hi Guys,
Im just new to Revit, doing an assignment and the interior render floors keep coming up blue and grainy. I have adjusted the sun settings, added more lights but it makes no difference. Can anyone please help me? Thank you.
Hi Guys,
6 REPLIES 6
Almost looks like a Speckle or Noise Procedural Map. Is it?
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-C...
syman2000
syman2000
What material did you use. Also do you have floor overlapping? This may cause it to render overlapping material.
...more Rendering time might improve. Step up the Quality Setting to Medium or Best.
in reply to: barthbradley
Thanks It is set to polished as it is polished concrete floor.
"Polished" doesn't mean anything.  Post a screenshot of the Material's Appearance Tab with all the categories (i.e. Bump, Cutout, etc.) expanded.
in reply to: syman2000
Yes this was the problem as i had a floor overlay, removed that and it worked. Thanks
