- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My office created a custom interior elevation tag based on what we used to use in AutoCAD. The problem is the sheet number box can't be moved based on which direction the elevation is pointing- see images.
We have the sheet number placed so that it looks fine with the lower right directions, but very disconnected with the upper left. (it'd be nice to be able to just drag the sheet number wherever you want without affecting the position of the direction boxes.
Is there any way to control the placement of the sheet number label based on which direction(s) is used?
I tried setting up Yes/No params in the family, but these params aren't accessible from the elevation tag settings. The family that controls the "look" is buried.
Any thoughts?
Thanks!
Matt
