@Anonymous wrote:
So this is partially the issue. The finish floor type was not on in the views that we were creating the elevations on, but it still would create the view wrong. I removed all instances of 1 finish floor types and that fixed the issue, but once we redraw any finish floor again it brings back the issue. I even tested everything out to see what would fix it. I changed the finish floor type, I changed the level it is hosted from, and even created a new one from an existing. Any new finish floor that is drawn creates this issue so it looks like the model has some sort of bug in it.
It is related to the position of the floors, and levels, etc... It is just the way Revit "reads" the geometry, there is nothing wrong or corrupt with the model. I spoke with one of the Revit "old timers" (I am actually one of those guys who is an old timer I think? ) about this some time ago and he described it was related to the way floors were positioned in relation to the levels. I can't remember exactly what the cause was. So basically what I am saying, is, it is Revit behavior, that is the way it works. If you are seeing it, it is probably just easier to manually fix it and move on.
Eventually you may see some kind of behavior change in Revit around it, but it is typically a pretty edge case in that it does not happen ALL the time.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
