Interface with Autocad Civil
steve
steve
Most Civil Eng's use Autocad Civil.   None that I've found use Revit Civil.   There are a lot of problems using their models since they use real-world co-orinates and project basepoints that are miles outside of the drawing limits.     We have solved by stripping their models like this... https://www.youtube.com/watch?v=nK6snx8vvy0&list=PLMxjwNMjYenRoStP_73yP0d54McnIUGVI&index=18&t=0s
I've seen this discussion.   https://forums.autodesk.com/t5/revit-ideas/use-project-base-point-and-site-location-to-locate-0-0-0-...   I think this still results in site plans that literally disappear into a pinpoint lost in zoom-extents void .
  1. Could this all be fixed by spec'ing that the CE should move their (real-world) project base point to inside the site somewhere?
  2. Other thoughts?
  3. Is there any solution within the Bim360 universe?  other Autodesk solution?
Civil 3D to Revit and Back Again
steve
Great info.  I look forward to reviewing it in detail.  Thanks.
loboarch
You may also want to review the topics in this topic cluster in the help. it covers the link topography workflow which is intended to relieve some of the pain points working with Civil 3D and Revit.
http://help.autodesk.com/view/RVT/2021/ENU/?guid=GUID-3419F2BF-98F5-4988-BA51-9C23FE23D37D
Jeff Hanson
Principal Content Experience Designer
Revit Help |
hmunsell
if you can get them to use the Shard Reference Point tool they can export out there locations data and it can hen be brought into Revit.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Howard Munsell
