instance parameter in a profile family not shown in the property panel of host family (for blend)
heichan88
heichan88
hello,
I creat a profile family (circle) with a simple rarius parameter R, then load to host family, then this R doesn't appear in the property panel , please advice, thanks
vitorbortoncello
Make it an instance parameter
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
heichan88
hello,
yes R is an instance parameter, please refer the rfa file uploaded above,
heichan88
hello friends,
any idea about that? normally "instant parameter" in a nested family can be seen in host property platte, but seem strange, I am using a student version, is that a reason?
@heichan88 wrote:
hello friends,
No it is not a reason.  Profile is type base so you cannot change instance parameters one the profile is used to for a geometry.  Edit type and change.
heichan88
Hello  @ToanDN
if so, (1) will shared parameter can work? (2) if I need to blend with 2 circle (one big one small) at two ends,  that means i need to create 2 separate profile family (just for 2 circles with 2 radius?)
Shared parameters make no difference. If you need two profiles then you need to create two types in the same family or in different families.
