Installing Revit Keyboard Shortcuts
mike55
Observer Observer
mike55
Observer
Observer
We are going through a fresh install of Revit 2023.
We do not have keyboard shortcuts.
I went to "https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-39D549F2-75EE-4C06-8B6A-3DADE1FBEF59"
and downloaded the XLS file: Spreadsheet containing default keyboard shortcuts.
Revit 2023 wants a .xml or a .txt file for importing in the keyboard shortcuts dbx.
If I export the current shortcuts list it exports as a .xml.
I tried save as .xml on the .xls file downloaded from autodesk.  This file fails to import with errors.  When I open and compare the two, column A is commandname, column B is commandid, however columns C and D are switched.
C is shortcuts and D is paths on the downloaded file vs D is shortcuts and C is paths on the exported file.  There are 1689 lines on the downloaded file and 1774 on the exported file.
I tried comparing and merging in a separate .xml file with the columns matching the exported .xml.  While it imported it did not load any of the new shortcuts.
Does anyone have a solution or work around for this?  It seems like the shortcuts should have loaded with the initial install.
Thank you
Are you just wanting the default shortcuts that are included in vanilla Revit?
handjonathan
Hi @mike55
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
