Installing Files on Windows 10 D Drive
Message 1 of 9
I have installed Revit 2018-2 on my D drive in windows 10 but all the library files installed themselves in the App Data folder of my now bloated C drive. Any reason I can not move my libraries to the D drive in a newly created App Data file?
Thad Broom
Replies (8)
Message 2 of 9
RobDraw
You can keep your library files any where you want. Just remember to change the path in your places so that when browsing for something Revit starts at a convenient location.
Rob
Message 3 of 9
Ah I wish it was that easy. Tried it but Revit tells me the path that I created does not exist. See attached error message and explorer open to the path that Revit says does not exist.
Thad Broom
Message 4 of 9
Viveka_CD
Hi @Anonymous
I suggest that you uninstall and reinstall again.
  • You will need to uninstall the content library entirely (through the Programs and Features Control Panel) and then reinstall from the original installation media. See article: Revit: Templates and families not installed
  • After installing the Content Library go through the steps in the above article to set the correct paths within Revit.
Message 5 of 9
RobDraw
It was that easy for me. I don't know why Revit won't recognize the file path.
Rob
Message 6 of 9
Viveka_CD
@RobDraw I've seen this issue with a corrupt installation.
If all fails, @Anonymous can do a Clean Install and Uninstall of Revit products
Message 7 of 9
RobDraw
I get that stuff happens with a corrupt install. Hopefully, when the install is proper it will be that easy for the OP.
Rob
Message 8 of 9
OK, got it to work...there is no space in ProgramData but there is one in RVT 2018.  Just directory syntax.
Message 9 of 9
RobDraw
Hmmm, you manually type the file paths?
Rob
