Installation
Installation
Installation
I can't download the material library. I t always stops a 268mb of 1.33gb downloaded. It has been like that the whole day. Here is the pictureof it. I hope you can help merevit.png
JvanReij
When I look at your error message the first thing that comes to my mind is: Proxy settings in your browser. This is also the easiest part that may solve this issue.
If you go to the proxy settings (IE = tools menu -> Internet options -> Connections tab -> LAN settings) you get a new window, where you have to click 'advanced'.
In this window you see: Servers    and      Exceptions.
At Exceptions you may add (copy) the following text:
*.autodesk.com; *.google-analytics.com; *.cloudfront.net; *.virtualearth.net; *.autocadws.com; *.newrelic.com; *.akamaiedge.net; *.amazonaws.com; *.getsatisfaction.com; *.autodesk360.com; *.skyscraper.autodesk.com;
After this, try to instal Revit 2017 again.
If not you can also try the following solution that is posted about a similar issue, when stuck at downloading material library.
Would like to hear if this solved the problem.
Best regards,
Josha van Reij
Arcadis NV
BIM manager
rudi.roux
Hi @Anonymous
Welcome to the community!
If the above-mentioned suggestions did no resolve your issue, I can strongly refer you to THIS SOLUTION. I used this method myself before when I had issues with my content libraries - which for the life of me just did not want to install. It is something funny with the MasterXML files.
This can all be found in the link which I provided along with step-by-step instructions.
I hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
rudi.roux
Good day @Anonymous
Hope you are well. I would just like to follow-up and hear if one of the answers posted in this thread served as a solution for you.
If so, please accept the relevant post as a solution so that other/future community members could benefit from it. Smiley Happy
Rudi Roux
LinkedIn
