Dear Forum,
The latest time when I import construction drawings from my partner (.ifczip) in my revit project, everything seems to be imported and loaded. But it aint visible anywhere.
Is there something i am doing wrong?
S.
Gelöst! Gehe zur Lösung
Gelöst von JvanReij. Gehe zur Lösung
Hi @Anonymous,
Hope you are well.
Just a few standard things which you could go through:
HERE is also a useful link which you could read through which will possibly assist you.
I hope this helps! ![]()
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
The above post from Rudi nicely covers the things that possibly cause it in Revit.
Since I experienced the exact same a little while ago, with something that had nothing to do with Revit, here by my post in case above solutions don't solve the problem.
If you 'partner'is using Tekla for the construction(?), there may be another way to solve the issue. I've noticed that the IFCzip export from Tekla ain't calibrating with Revit perfectly. Some of the models I gain from customers out of Tekla give the issue as you describe. So, first try the solutions from Rudi, if these ain't solving the problem, you can try the following:
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Hi guys. I have just discovered the issue.
I don't know why but in some cases, when opening ifc, it gets open with a selected phase in the "Phase creating" box (properties menu). If you change it to "None", everithing appears in the views. I am working in a collaborative team and some of us could see it well and some others not.
Greetings!!
