installation
installation
Message 1 of 17
installation
I am trying install revit 2017 . After installation I click on the EXE file and it doesnt run at all.
My system is 64 bit with windows 10.
Replies (16)
Message 2 of 17
robert.klempau
Hello @Anonymous,
I would suggest you try solution in the link below.
2017: How to Complete a Clean Install and Uninstall of Revit products
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 3 of 17
the issue is that it does NOT even start the installation process.
Message 4 of 17
Message 5 of 17
I finally managed to insatll it afetr i restarted my system. However the issue is that I don't have site design options , and some of the other features also failed to install. I have tried to install the extension but it coud nOT load as I am using revit 2017.
https://apps.autodesk.com/RVT/en/Detail/Index?id=7736908368798857578&appLang=en&os=Win64&autostart=t...
Message 6 of 17
ennujozlagam
@Anonymoushello mate, if you under subscription go to your account under product update it's a separate file that need to install. thanks
Message 7 of 17
HOW CAN I go to that page ? I cant find that page
Message 8 of 17
ennujozlagam
@Anonymous hello mate, are you under autodesk subscription? if yes here is the LINK . thanks
Message 9 of 17
I have found it but another issue is taht I can NOT  open family templates
Message 10 of 17
ennujozlagam
@Anonymous hello mate, you need to go to the top left corner big R > options > file location and load the template. thanks
Message 11 of 17
I cant load it undortunately . I can NOT see any RTE files at the destination.
Message 12 of 17
robert.klempau
Open the installation package and install the library.
See:  Revit: Templates and families not installed
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 13 of 17
ennujozlagam
@Anonymous hello mate , go to your window explorer > program data and check if you installed the templates/library, if not then just follow @robert.klempau suggestion you need to install it. thanks
Message 14 of 17
I had read the article a while ago but the issue is tath I do NOT have the revit content library in the control panel unfortunately.
Message 15 of 17
i do NOT have the directory or any template folder in my whole computer
Message 16 of 17
I always used one of the steps you guys suggested before biut my issue now is that I do NOT have any template folders on my pc at all.
Message 17 of 17
