installation error
installation error
Message 1 of 9
installation error
good morning. Ihave been unable to install my Revit 2020
please let me know what I can do. thank you
Replies (8)
Message 2 of 9
Did you press on that "How to Fix" button under NET Framework?
Message 3 of 9
yes it does no show any solution
Message 5 of 9
Message 6 of 9
Hate to tell you this... but you are going to have to update your computer.  Autodesk won't support Revit 2020 trying to be installed with Windows 7.
Message 7 of 9
Tony_Michniewicz
I would like to clarify that Revit 2020 is supported on systems running Windows 7 SP1.  Here is the exact quote from the Revit 2020 system requirements page: Microsoft® Windows® 7 SP1 64-bit, Enterprise, Ultimate, and Professional are supported but not recommended.
As far as this installation problem, it is most likely related to Microsoft Windows Hotfix KB4019990 for Windows 7 not being installed on this system.  Once that issue is resolved and .NET Framework 4.7 is able to be installed, the Revit 2020 installation should complete.
Tony Michniewicz
Revit Software QA Analyst
Message 8 of 9
@Tony_Michniewicz: Are you aware of any issues with 2020.1? Specifically, with error dialog boxes not displaying properly?  Supposedly, this has been posted about several times, including here today @
https://forums.autodesk.com/t5/revit-architecture-forum/error-dialog-box-missing/m-p/9079790#M256903
Message 9 of 9
Tony_Michniewicz
User feedback and testing indicates that this issue is related to the Revit InfraWorks Updater 2020.1 add-in.  An updated version that includes a fix for this problem should be available in the near future.  Until then, the only known solution is to uninstall the Revit InfraWorks Updater 2020.1 add-in.
Tony Michniewicz
