Infilling element replaced by a later phase insert must be the same type as the
robertovalentino
Message 1 of 42
robertovalentino
 Hi all
I keep having the following quite annoying warning in a project of mine every time I try to change a wall
"Infilling element replaced by a later phase insert must be the same type as the insert's host."
I have been using Phases for ages even on a quit complex project and this is the first time i see it.
Any suggestion?
thank you so much in advance
Replies (41)
Message 2 of 42
I've had them before. It's an order-of-operation thing usually.
Does this sound like your particular issue:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 3 of 42
You get the error message if you change the wall type after you already demo'd something from that wall in the next phase(s).
Message 4 of 42
robertovalentino
Actually I got no demo at all
I just added windows in the next Phase
Anyway I tried to flatten all the phases leaving only one and I still get the error
quite annoying
Message 5 of 42
@robertovalentino wrote:
 Hi all
Any suggestion?
That wall.  Did you draw it from scratch or did it appear from demolition of an older phase door/window/opening?
Message 6 of 42
A new window or door in an existing wall is going to still have an infil element, only it is something being removed.
That is why you see dashed lines where the window/door is being removed in the demo view.
(this brings up another issue already mentioned in the Ideas that the line of the width of the wall should show as well)
Message 7 of 42
And here I just tested it out and I cannot replicate.  I know I have gotten the error message too.  But I had an existing wall with an existing door to be demo'd, a new door in the next phase...changed the wall in Existing and New and no issues.  (shrug)
Message 8 of 42
robertovalentino
hi,
this is what I did
1 - I drew the wall X in Phase A
2 - I added windows in Phase B (phase B is after phase A, I need that because i need Revit to count wall area without windows)
3 - I try to replace wall X with wall Y
4 - I got error 🙂
thank you so much for bothering to help me out, really appreciated
Message 9 of 42
You missed the part describing how you replaced "wall X with wall Y". What method did you use?
Message 10 of 42
Here is how I replicate it:
- create a wall under Existing, demo it under New
- place a door under New in that wall
- set the view's phase to New, phase status to Show All, change the infill wall to a different type will trigger the warning
I know the whole scenario doesn't make any logical sense but there it is.
Message 11 of 42
It's documented, @ToanDN.  Incident ID: 118921
Message 12 of 42
Edit:  I tried the incident 118912 steps and I can change the wall type no problem.  What gives?
Sightly different:
Documented Incident ID 118912:
  1. Create a wall in existing phase.
  2. Place a window in existing phase.
  3. Demolish the winodw in new phase.
  4. Try to change the wall type.
My test:
  1. create a wall under Existing, demo it under New
  2. place a door under New in that wall
  3. set the view's phase to New, phase status to Show All
  4. change the infill wall to a different type will trigger the warning
P/S:  What's with the typo in a official document?  Sloppy!
Message 13 of 42
Alfredo_Medina
Isn't there a contradiction in that sequence?  "Place a door under New in that wall" (in the wall that was just demolished in the previous step) ???
Message 14 of 42
It works just fine for me too.  What version of Revit are we supposed to be working with?  I have 2017.2.
Message 15 of 42
Okay, we'll add yours as Incident ID:118921.
What's the method @robertovalentino used though? Maybe it will qualify as an Incident ID: 118921.2.  Smiley Wink
Message 16 of 42
Please read the last sentence.
Message 17 of 42
Works for me too, @Anonymous. That's why I'm asking how @robertovalentino did it.  Maybe this isn't a Chernobyl incident. Maybe it's just an order-of-operation thing like I first said.
Message 18 of 42
@Anonymous @barthbradley
What works for you guys?  The documented incident or the way I replicate the error?
Message 19 of 42
Answering for myself; I can draw wall X in Phase A; add a windows to wall X in Phase B; replace wall X with wall Y in Phase B.  Pretty much @robertovalentino's workflow, but without the error.
Message 20 of 42
Now this one makes more sense and will create the error:
  3. change the infill wall to a different type will trigger the error.
Only doors trigger the error.  Windows do not.
