Increment in Array family
Mat.Syaf
Message 1 of 16
Mat.Syaf
Is there a way to make an icrement count in array family. When the family is strected, the amount of block will be added and there will be a number on it that count how many block its appear. I don't think it can be happen in the family because array is fix block but there is something with Mark parameter. I am not really sure about it. Can someone explain  and how to make the Mark value appear in the family. Thank you
https://bimchapters.blogspot.com/2018/11/mark-and-type-mark-parameters-in-revit.html
Replies (15)
Message 2 of 16
Is the Arrayed Component a Nested SHARED Family?
If it is, you could do it manually in the Project.  If you were to Array a Door in the Project and Tag All, each Tag (that reports "Mark" value) would read an incremental number.  See where I'm going?
Message 3 of 16
You can TAB-Select and Schedule Nested SHARED Families in the Project.
Message 4 of 16
Mat.Syaf
the arrayed component is build in the family itself. It is not another family. Do I need to make it as another family first, make it shared and load to the array family?
Message 5 of 16
Mat.Syaf
ok I understand about the mark tag but just as per video below, when I tag the family, there is no number appear and has to key in the number 1 by 1. And is there any other way than use Mark parameter.
(view in My Videos)
Message 6 of 16
Yes; that is the very first thing you need to do. That Nested, Shared Family is the thing you are going to Array in the Host/Parent Family.
Message 7 of 16
Like I said, you are going to be manually inserting a Mark Value (or whatever Parameter the Tag is reading) by TAB-Selecting each the Arrayed Component in the Project to get to its Properties. Or you could use a Schedule to do this. Like I said above, Shared Families will show up in Schedules.  Add the Parameter Field that the Tag reads to the Schedule and enter cell values for each Component there.  That's a lot easier than TAB-Selecting each Component.
Message 8 of 16
Mat.Syaf
Got it!. Thanks for the reply
Message 9 of 16
Mat.Syaf
Hi @barthbradley , I just create family with instance Merch_Text and Merch_No parameter and nested the family into parent family and create array family, but after load the parent family into project, I cannot change the nested family parameters. why? the parameter is already set to instance.
(view in My Videos)
Message 10 of 16
Post the family here as an Attachment to a reply post.
Message 11 of 16
"1Desk" is a Shared Family that is nested into and Arrayed in another Family. Host Family is loaded and placed in Project. Tag is reading Comments and Mark Parameter values of each "1Desk" Instance in the Array.  Comments/Mark value can be edited via TAB-Selecting the individual 1Desks or via a Schedule.
Message 12 of 16
Mat.Syaf
Hi @barthbradley , here I attached the model. I used new parameter which area Merch_Text & Merch_No.
Message 13 of 16
Don't add the custom shared parameters to the Family. Add them to the Project as Project Parameters assigned to Generic Model Category.
Message 14 of 16
Message 15 of 16
Why don't you create the array using a curtain wall with custom curtain panel family for the arrayed components?  Then Tag All and use DiRoot One ReOrdering tool to set the order.
Message 16 of 16
smitharon550
Community Visitor
Community Visitor
Good discussion. This is similar to how counts are managed on a page values are controlled through parameters or logic rather than directly inside an array. Using Mark or Type Mark seems like the right approach.
