I would like to know if any workaround exists to get a inclined 3d section view similar to that we get in Sketchup or Archicad. Attached a sample of what I wish to achieve in Revit.
Wish List:
In the very early versions of Revit, when we put a detail section in elevation view in inclined fashion, we could go to 3d view and orient it to the inclined section. But in later version it was removed.
Any inputs would help.
Thanks in advance.
Aruna
Solved by Karambaki. Go to Solution.
Hi Dear, for now it is not supported in Revit,
There's a workaround but it's gonna be outside of Revit,
Using A360 viewer for projects,
Then u use section analyse (X, Y or Z plan) then modify it the way you want,
If this serves your needs tell me for further how to
Example :
http://a360.co/1QC6WtJ
Image :
Thank you Karam.Baki, I was not aware of this feature in A360.
Thanks for the info.
Aruna
