inches / inches = inconsistent units
5 REPLIES 5
kgatzke
876 Views, 5 Replies
I want to enter a height value from standard pitch notation like 1/4" for roofs, etc. and get back an angle value to slope part of a family.  I get the right angle if I put in 'atan(12/.5)' but everything I try to do to replace .5 with a parameter based on pitch results in some kind of units error.
5 REPLIES 5
kgatzke
in reply to: kgatzke
Nevermind, I see what I did wrong.  "Angle" was created as length.
kgatzke
Nope, still getting an error.  It calculated the angle correctly and then give me this...
rodrigo.bezerra
Since Revit works with distinct kind of parameters (such as angles, integers, area, length), the outcome of an formula must be exactly what a parameter expects to be.
Ex. 1 meter x 1 meter = 1 sq meter. So, if the result of my formula is an area, my parameter must be an area parameter.
"But I want the value, not the meaning of it". Well, then you have to add to your formula a math way to solve it. Ex: (1 meter x 1 meter)/1 meter = 1
This is my guide for formula issues.
Rodrigo Bezerra
You have another FAMILY TYPE that is erroring out. Not the one showing in your screenshot.
1/2" tapered - 2" thick
kgatzke
in reply to: barthbradley
Which was probably set to 0 by default resulting in a divide by zero.   Problem was solved however by modifying a similar where everything worked.  No angles were used in that one.  The pitch was created by the difference between two reference planes and a boring ratio formula, all units in length.  Thanks.
