In the new 2017 where is the Create Deployment option?
dougf
Observer Observer
dougf
Observer
Observer
I'm running 16 pc's on a single license server.  I've downloaded the new Revit (2017) but during the installation process it wants to install revit on my server and not give me a create deployment option.  I've created several of these of the past several years and it always had a seperate selection to Create the Deployment instead of just the install.  does anyone know where the deployment option went?
SteveKStafford
I believe you can cancel that process and run the setup.exe afterward from the folder and you'll get the usual dialog you are looking for. Just make sure the download finishes first!
Steve Stafford
Kgoode
Community Visitor
Community Visitor
Hello Doug,
   Were you able to find the create deployment option.  I have run into a similar scenario that you have and I can not find an answer.
Thank you in advance.
dougf
Observer
Observer
I still have not found a solution to this deployment problem.
Tony_Michniewicz
The Create Deployment option is not available through the Autodesk web installer.  You'll need to DLM or browser download version, both of which support the creation of deployment images.
Tony Michniewicz
Revit Software QA Analyst
