In need of Revit 2018 Version
We are working on Revit 2020 but we landed a project and the MEP they only have 2018. Where can I get a download copy to check that project and save some of the changes we need to apply? Because we need to be in the same version.
DarrenP
you should be able to get it from your Autodesk Account here: manage.autodesk.com
DarrenP
aRcHiTeCt.JM
... hi @Anonymous
... REVIT 2018 version.
... check you personal message
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Check here to see if you have Previous Version Rights:
https://knowledge.autodesk.com/customer-service/account-management/users-software/previous-versions/...
If not, you may be able to switch your Plan through your Autodesk Reseller.
Thank you I don't have an autodesk plan. And it is just to save some changes in the project. The 30 day trial is enough.
@aRcHiTeCt.JM wrote:
... hi @Anonymous
Thank youthat is good. I will be using this only for a few days.
Thank you. No I cannot find the program there to download, but I already got it. It is working perfectly in trial mode. I don't need it for anything else.
