imprted symbols not showing in properties menu
When I load in a symbol family, it doesn't show in the properties menu. screencast recording for reference
ennujozlagam
try to go to your project browser > families and search for the family, drag and drop. and see if helps.thanks
ennujozlagam
is this a revit family? share some sample here so we can check. thanks
ennujozlagam
If is not a Revit family, it's nothing, it's just a few lines to revit and no applicable properties of information that Revit will recognize. Thanks
Thank you for the quick response. It is family file, I have used it in several project.
The problem has been solved. As Revit acted as if it was loaded in, I checked for it, and it was in project browser, just without the actual symbol.
So had to delete it and reload
ennujozlagam
so i'm right you can find it from the project browser. so did i help you? thanks
