Can't see in Floor Plan - Model is far away
hesham_hafez
hesham_hafez
Hi
I am working with some structural element modelled by Dynamo and Excel. The problem is the objects coordinates are nearly 2000m in x, 6000m in y, and 14.2m in z and I only can see the objects by selecting one element in entire project and zoom selected by the cube but I can zoom selected in Floor Plan/Elevation and I don't know what to do.
Is there any way around that?
ennujozlagam
it could some objects/families are far from your origin or maybe some 2d files. try to zoom to fit or draw a selection box  around whole view in one of your view  this can help you to see the objects is far from origin. thank
hesham_hafez
Yes I did that. I can select window the far away elements but still are not visible and I can't zoom to them plus I want to see them in Floor plan all the time.
It's an easy fix.  What's preventing you from moving the far away elements closer to the Internal/Project Origin?
hesham_hafez
Thanks it worked
