Impossible to remove vertical line snap
s252499
Message 1 of 12
s252499
Hello!
I am working on a structure which has several diagonal constructional features (so, it's impossible to have the structural grid strictly orthogonal). When I need to draw a model line, I often encounter a problem that it does not snap to endpoints, but just goes vertical (snaps to vertical axis). See screenshot attached.
I tried to turn all snaps on/off, check/uncheck them, but nothing works. I don't want it to snap to ortho, only to end- or midpoints.
I couldn't find any solution on the web, everyone just says "turn off the snaps", which, as I said, does not work for me.
I would be grateful for your suggestions.
Replies (11)
Message 2 of 12
alan.johnson7YLND
Did you try right click > snap override
Message 3 of 12
s252499
I did, it doesn't work.
Message 4 of 12
pedruccioli
Have you tried using TAB?
I often have slightly off-axis as-builts and I just press tab when trying to snap to something that's not orthogonal.
Architecture Modelling, BIM Workflows and Information Exchange.
LinkedIn
Message 5 of 12
alan.johnson7YLND
I think it will always have a vertical / horizontal 90deg snap but you could try setting the snap angle you want in the Manage Tab > Snaps > Angular dimension snap increments
Message 6 of 12
Message 7 of 12
s252499
I did, unfortunately didn't work for me...
Message 8 of 12
Model lines need the be drawn on a work plane.  Do draw them free from work plane, use structural framing and turn on 3d snap, or create a mass in place and draw model lines with 3d snap.
Message 9 of 12
s252499
Unfortunately this also did not work for me.
It's normal that axes snaps are present, but I don't believe there is no possibility to make a slightly diagonal element/line....
Message 10 of 12
josip_zdrilicE5DGA
Community Visitor
Community Visitor
i encountered the same problem while modeling from point cloud, as we want to have a real as build, that is not perfect 90 degrees.
What i di is i used the angular snap, but instead of the 1 5 15 45 90 or whatever degrees, i added 1 2 3 4 5 degrees.
So the steps are much smaller in between.
Hope that helps
PS: I drives me nuts as well that u can turn off the ortho like in autocad.
Message 11 of 12
david3L739
Community Visitor
Community Visitor
Worked for me thank you!
Message 12 of 12
shineoooo
The TAB key works for me! Thank you!
