Although the sheet revision box is black in the Revit and print print preview, text is grey in PDF.
Gelöst! Gehe zur Lösung
Gelöst von lucdoucet_msdl. Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
What happens when you change the font type to something else (e.g. Arial)?
Louis
Please mention Revit version, especially when uploading Revit files.
In your revised screen capture, did you use the Windows Arial Font or another font?
If yes: that's not the Arial typeface and you may have a font substitution problem;
If no: try it with Arial instead and check to see what typeface you are using. Is it a Truetype (TTF), Open type Face (OTF) or other format.
Revit does not always play nice with formats other that TTF.
-luc
Would you mind replying to this conversation thread of what the solution actually was so that others may benefit from your experience?
I suppose changing the font selection was the answer but there are workarounds to making other font file formats to work.
-luc
