Importing Solidworks model into Revit
I have some Solidworks (.sldprt) model files and would like to use them in my Revit file (most preferably Revit Family). Can't really find a way to do it properly and to see which format would be most editable after importing it in Revit (sat? dwg? dxf?).
I do not work in Solidworks...
Thanks in advance!
Save them to SAT files and import to Revit Family.
Viveka_CD
Hi @Anonymous
Please check out the following video:
See the discussion HERE for a similar import question
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. - Thank you.
Sahay_R
Please remember that most probably the geometry that you use to create the family would end up being 'dumb' geometry. You would be able to make better use of the parameters in Revit by modeling families from scratch and controlling them with parameters - besides getting less annoyed.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Have u tried BIMDeX SolidWorks to Revit Exporter. With that, you will be able to export your SolidWorks model to native Revit Family file with existing hierarchy and parameters maintained. Refer the below video
jebinabraham
do watch this video on youtube.
https://www.youtube.com/watch?v=YxQunYPqvOY
By this method you can easily add solidworks model into revit with ease and use them as family.
