Message 1 of 10
I am copying sheets from another project into my current project. I went to the insert tab, selected "Insert from file", then selected the previous project file I am copying from. When I select the sheets only option, it is not loading all the sheets from that project. (For example, it will show sheet A2.1, but not A2. It shows A3, but not A1.)
Can someone explain why not all the sheets are appearing in the checkbox for import?
Any help is appreciated, thank you.
