How to add TYP SIM OPP to section/callout tags?
7 ANTWORTEN 7
Nachricht 1 von 8
Anonymous238
554 Aufrufe, 7 Antworten
I see this topic posted many times decades ago and people just saying to add text next to section and callout tags for TYP SIM OPP. There has to be a better way now right? How can I have a simple text box near my tags that I can write anything in for each instance of the tag?
7 ANTWORTEN 7
Nachricht 2 von 8
RSomppi
als Antwort auf: Anonymous238
It sounds like you are coming from AutoCAD or something similar. Sure you could add a lable to the tag and have it behave like an attribute and type the value into it but it is easily solved with 3 tag types. Simply select the type that you want.
Nachricht 3 von 8
Why are you opposed to just adding the text notation?   What are you wanting to improve upon?  Doesn't sound systematic if you want to be able to "write anything".
Nachricht 4 von 8
Anonymous238
als Antwort auf: RSomppi
I just duplicated the callout to make 3 kinds, but if I change one callout all the other callouts change too...
Nachricht 5 von 8
Anonymous238
als Antwort auf: barthbradley
so I can universally change all SIM tags to OPP by changing one instance
Nachricht 6 von 8
That's done via Type Parameter.  There is no Instance Parameters. I thought you wanted to have different notations per Instance.
Nachricht 7 von 8
RSomppi
Then they are all the same "kind"/type? When done correctly, my suggestion works. Share what you have for help.
Nachricht 8 von 8
Use text.  There is no better way.
