Importing IFC from Tekla into Revit
adimariaBXE2A
adimariaBXE2A
Hi, I am having issue when importing IFC into Revit: the authoring software for the IFC is Tekla and so containing steel structure components. When I import the IFC into Revit, everything shows as bounding boxes. Did anyone experienced the same? Any solution?
TripleM-Dev.net
I assume it's displaying correct in a IFC viewer?
What do you mean "import", was the IFC opened in Revit or linked.
I suggest to link it not open, with open Revit will try to generate Revit objects and maybe those boxes are void that exist in the IFC.
adimariaBXE2A
Hi @TripleM-Dev.net, correct the IFC displays well in IFC viewer, e.g. Naviswork, BIM 360.
The IFC is linked in the Revit file.
azad.Nanva
Use Open IFC file ,in your revit file you can control everythings , and save the Revit file and import the link of Revit file.
adimariaBXE2A
Hi @azad.Nanva thanks for your suggestion, but it did not work. I have opened the IFC, but once the processing was completed, there was not geometry at all converted.
TripleM-Dev.net
Might be a option to look at the source, see if the owner of the IFC can change the export to IFC in Tekla itself? or Experiment with it?
https://www.tekla.com/solutions/design-interoperability/autodesk-revit
Ps. Can you share the IFC?
