importing cad data
importing cad data
importing cad data
Hello Everyone
i am trying to import the cad data file into revit
and the problem is that the cad data is not completely imported in revit
i dun  understand why
Please help me
thank you so much
waiting for your reply
dzanta
it looks like their is some kind of corruption in the cad file which Revit cannot translate.  You may have to rebuild the cad file prior to turning it into a family
you can try to import just one pipe run at a time to find the offending object
see the attached image of what I see when looking at the cad file in autocad 2019 (rotated 3d view/2d wireframe)...looks like some of them are not same as others
alternatively
if you can see the existing family in Revit as is, use the Pipe command to redraw the family within the Project Environment.  It isn't the best solution but it may work for what you are trying to do
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
