Changing thickness and offset of a floor at the same time
MVE1112
MVE1112
Hello, Here i am again with the same problem.
5 weeks ago i made a ceiling with a thickness of 300 mm, with a level at the top of the ceiling, they wanted me to change the thickness to 350mm.
So as a true genius i just offset the floor 50 from level and made it 350mm, so the inside of the building would not change.
Now, 5 weeks modeling later it needs to turn back to 300 mm..
If i change the thickness, revit immediatly gives about 80 errors but if i can change the offset to 0 and the thickness to 300 in one "command" this wouldnt happen.
So in short: Is there a way to force revit to wait with changing the thickness of the floor until i set the offset to zero?
