Importing a Sketchup Model into Revit 2020 family, cant remove Geometry Lines
2 REPLIES 2
2097 Views, 2 Replies
Hi I am a student learning Revit, I have been trying to import some 3D objects into Revit 2020 from Sketch up and Rhino, I have gone into sketchup explode the object and created layers export as a dwg.
In revit I have created a new family (furniture) import the saved dwg file, it appears as this wireframe object and I am unsure of how to change this. I have tried a few different file types and they all appear like this. I have tried a few different things while exporting the file in Sketch up, saving as version 6, in options selected to retain faces, or faces, edges, construction geometry that looks like wireframe.
Tags (2)
2 REPLIES 2
I would go about it a little differently. Import the SKP into AutoCAD (via "Import SKP" addin) and modify there. Then insert the dwg into Revit.
ennujozlagam
you can try this > open a Metric Furniture.rft as shown > import your furniture as .dwg > change your visual style: shade / realistic > saveas > give family name > load into your project (become loadable family) and see if helps. thanks
