Imported IFC problem
I have a question about Revit. Im importing a IFC file to Revit. The IFC file is made from Archidat. I need to give some collors to the objects in the file. These are the staps i take. Opening revit with a standard architectural file, open the IFC file with an plug-in then when the IFC file has been loaded, I go to manage and select paint. I choose a collor and I try to paint a object. But this dont work.
Can someone help me with this problem?
Mohamed-Nassar
First open it with Navisworks to Edit Colors before import in Revit.
Regards,,
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
