Calculating with yes\no parameter
DFcheee
Message 1 of 12
DFcheee
I have extract area information from my project and I want to totalize some of it. I have created different Yes/No Parameters for those I want to calculate. My question is how to do it, or whats the formula for it.
Replies (11)
Message 2 of 12
XXalessio.amodioXX
Sort by Yes parameter>Ground totals>Area calculate totals
Message 3 of 12
TripleM-Dev.net
You created "Different" yes/no parameters? Does this mean multiple yes/no or just one with different values?
Which condition should be evaluated?
You can simply filter out the elements in the schedule itself, unless it's more than 8 or needs a "OR" compare and not "AND", then you could use a Calculated Field and filter based on that result.
Maybe post a image of a schedule with the parameters/values and the desired elements marked?
- Michel
Message 4 of 12
DFcheee
still not calculating it right
I wanna collect the one mark with yes in the last column
Message 5 of 12
TripleM-Dev.net
Hi, I assume you don't want to filter out all values? otherwise it would be easy, just apply the yes/no parameter in the schedule filter.
To keep all values and only count area's of Yes in a specific Yes/No column.
Use a Calculated value field to "duplicate" only desired values to a calculating column (Area3 in this case)
See the formula in the Calculated value.
Endresult, only desired area's are "duplicated" in the Area3 columnEndresult, only desired area's are "duplicated" in the Area3 column
First add a Calculated valueFirst add a Calculated value
Set the new field to Calculate totalsSet the new field to Calculate totals
And setup the Sorting/Grouping/Headers etcAnd setup the Sorting/Grouping/Headers etc
Message 6 of 12
XXalessio.amodioXX
You have 3 Yes/No parameters.
-First assign the grey out parameter (Are they Yes or No?)
-Second wich one of Yes/No parameter you want to sort?
Message 7 of 12
DFcheee
Thank you very much!
xoxo
Val
Message 8 of 12
TripleM-Dev.net
@XXalessio.amodioXX , the "grey" values (uninitialized parameters) shouldn't be a problem as long as you only want to filter on Yes OR no. If both values have to be accounted for, all should have a value, that's correct.
@DFcheee wants the last column to be used, although the first marked area value doesn't have a Yes associated in the last YesNo column, so..?
- Michel
Message 9 of 12
DFcheee
Darling, dont hate the blond woman :D, but is there a chance you could know how to divide the total I got from this exercise to the one highlight in green value I didnt add in calculation, the top one. If its not to much to ask about.
Message 10 of 12
TripleM-Dev.net
Uhm, maybe I'm getting blond...I need some more info
You want the Sum of the Green fields in A to be divided by the B value?
That's possible, but I would need a unique identifier for the field, and has to be a number or YesNo parameter?
Message 11 of 12
DFcheee
You want the Sum of the Green fields in A to be divided by the B value? - Thats exactly what I want. Not sure which is better, the number or yes\no, but I do believe that y\n will work for me.
Message 12 of 12
TripleM-Dev.net
Small correction, pointed out the wrong button for adding a Calculated value.
Seems can't get the Divide calculation going, the divide by 0 gives problems.
In the past with percentages I could work around it, I can't seem to get it working for numbers
- Michel
