Transfer levels from conceptual mass family.
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
478 Aufrufe, 3 Antworten
I've created a conceptual mass family that contains the levels that I want to use in the project that I want to create with the mass. Is there any way to transfer the Levels that I've created in the family to the new project? And also, is it possible to create gridlines in the conceptual mass environment?
3 ANTWORTEN 3
Nachricht 2 von 4
hmunsell
als Antwort auf: Anonymous
someone else can correct me if i'm wrong, but i don't think you can. my understanding of the levels in a Conceptual Mass was just for use in the mass.
depending on the shape(s) in the mass you may be able to load it in your model, then place a level and align it to the mass top/bottom shape(s)?
Howard Munsell
Nachricht 3 von 4
als Antwort auf: hmunsell
That's what I was affraid of..
Maybe something for autodesk to consider for future updates. It's not a lot of extra work but still something that would make it easier to take a conceptual mass and transform it to a real project.
Thanks for your help @hmunsell :leicht_lächelndes_Gesicht:
Nachricht 4 von 4
hmunsell
if no one else chimes in saying otherwise :-), you may want to put it in as a topic for the Ideas Forum. https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Howard Munsell
