imported dwg not visible in floorplan
76jsa
76jsa
just a basic thing - linked cad file to floorplan - it is not visible:
- no scope box
- no crop view
- no depth clipping
- not just hidden
- imported categories are on in template view
When 3D view is opened,  I can see that linked CAD to that floor,  but not in floorplan view.
Thanks for help
ennujozlagam
have you tick current view only?Instead of imported dwg, try link cad file, and tick current view only and easy to manipulate. Thanks
dferreira-blackwell
pls see post above and confirm if it is solved, above post suggest the perfect solution.
Have you checked to see if it's a View Graphic Override applied to Element? Reveal Hidden Elements.
 No it is not. If you checked that box you would never see the DWG in 3D.
To @76jsa , try increase your view range and turn on wire frame.
mahmetoorhano
Observer
Observer
This solved the issue in my whole project. Thank you!
mahmetoorhano
Observer
Observer
This solved the issue of my whole project. Thank you so much!
