IMPORTED DWG MATERIAL APPEAR TO BE STRETCHED
i.yad95
i.yad95
Hello...
I have been struggling with this issue for my whole life in Revit and yet I cant seem to know what is the problem exactly
I do import blocks from 3DSMAX and import them in AutoCAD and convert it to Revit Family but when i apply material to this family some parts of the family appear to be stretched as you can see in the image attached.
Please help :'(Screenshot 2022-08-16 135614.jpg
Edit the Asset Image and change it's scale/size.
You might need to apply several variations of the Image (each with different scaling) to the different surfaces of the model.
i.yad95
Thank you.
but because its an imported object I cant divide surfaces to match with the material. I'm pretty sure its something in 3dsmax I need to do. maybe something about how the material wraps around surfaces and objects.
pacatancharleslou
Community Visitor
Community Visitor
Do you have now the solution to this problem?
