HOW TO CUSTOMIZE ELLIPSOID DIVIDED SURFACE?
3 ANTWORTEN 3
Nachricht 1 von 4
tomas.tZZX6Z
243 Aufrufe, 3 Antworten
Could anybody explain how to change the default ellipsoid divided surface. When dividing surface I get such pattern:
I would like to get such division - especially at the ends:
Any ideas?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: tomas.tZZX6Z
Are you asking about the divided surface pattern?  Looks like a Triangle to me.
Nachricht 3 von 4
tomas.tZZX6Z
als Antwort auf: barthbradley
Yes it is "triangle flat" pattern, but the question is how to change the grid, that lines wont come at the end to one dot:
The grids should go like this:
Nachricht 4 von 4
Slice the Ellipse above the axis with a Void to remove the bottom portion.
