IMPORTED CAD FILE PROBLEM 1E9
Soytei
Soytei
Hello, I am trying to link a CAD File with the topographic file of my project and there is no way for it to be imported correctly.
I keep getting a message that says "the file has geometry with extensions greater than 1E9. Data that exceeds this range will appear truncated."
I click to accept and the file appears, but completely distorted and functioning poorly.
Any ideas to repair the file and make it work correctly? I leave you an image of what the imported file looks like.
jay_colc
When importing you can use the option to specify a Position closer to the Revit internal Origin and then is needed  Acquire Coordinates or Specify Coordinates at a Point if required.
Jay Colcombe
Autodesk Certified Instructor
Soytei
Thx for your quick response, but It doesn`t work. I'm going to try to import layer by layer to a new CAD file, and maybe in that way I'll find what is creating this error.
jay_colc
Good luck.
One thing to note, if you have Hatches try deleting those as they have their own Coordinate System and are very problematic when models are far from original.
"Geometry in the file FileName.dwg has extents greater than 1E9..." when linking a CAD file into a m...
Jay Colcombe
hmunsell
When dealing with Civil files into Revit i always refer people to this class from AU2022....
Howard Munsell
GHASEM_ARIYANI
hi
in the Autocad file:
1- select all topographic drawings.
2- M enter
3- select the base point a corner of the drawing
4- type SHIFT + #, then 0,0,0 and Enter
5- Z enter,  E enter.
6- UN enter and set Untits, for exam Meter.
7- PU enter and Purge.
8- Overkill Enter and Select all Drwaing then Enter.
9- Save the AutoCAD file.
10-the Revit, Insert tab, Import/Link CAD.
11- Positioning > Auto - Orgin to Internal Orgin.
12- Import Units > Meters.
13- Open.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Soytei
Thx to all,
hmunsell,
jay_colcombeI think that the solution depends on each case but with your answers is easy to find a solution.
In my case I copied the layers that were necessary  and "it worked".
