Dimension Space
Dimension Space
Yasser_musa
Observer Observer
Dimension Space
Yasser_musa
Observer
Observer
Hello Everyone,
I would like to enquire, is there any way that I can modify the existing dimension to my desired Dimension Space (as shown in Red example below) ?
I am optismic and thanks a million from your answer.
Best regards.
jay_colc
You have the option for one Dimensions Snap Distance in the Dimension Style > Type Properties
Is this what you wish to Achieve? you could have multiple Dimension Styles for each distance requirement if not equal
Jay Colcombe
Autodesk Certified Instructor
Yasser_musa
Observer
Observer
Hello Jay,
Thank you for immediate response to my query. What I wish to achieve to have is easy solution to existing dimension command in Revit comparing to AutoCAD command DIMSPACE.
jay_colc
That is the only option in Revit when you place a Dimension is snaps at that distance and if you need to edit existing dimensions you can click on the Line and Drag until it snaps, so this will do the same thing in theory but more of a manual process.
The only other alternative is an add-in from the Autodesk App Store which can be free or on a paid subscription
Revit Store: Plugins and Add-ons for Revit | Autodesk App Store
Jay Colcombe
