Hello dear people,
I have created types for the Spot Elevation System family. Now I want to remove many unused types. The command "purge unused" is to be avoided, firstly because the program crashes every time I use it and secondly many unused families are still to be used in the canvas and should not be deleted. Is there a workaround or a known plugin?
Thanks for all contributions
Gelöst! Gehe zur Lösung
Gelöst von jay_colcombe. Gehe zur Lösung
Have you tried deleting from the Family List in the Project Browser using the Shortcut Menu? (You can hold CTRL to select multiple Families)
somehow i cannot find the family in the browser. I tried even to paste the family or type name in the search bar, but nothing to be found.
Usually with Tags you have a System Tag Family with an Annotation Tag embedded within it!
Could this be the issue?
Try inserting a Spot Elevation and then review the Type Properties to see which Annotation Tags are being used.
i removed all Annotations families, but spot elevation is still there with all not wished types
You cannot delete System Families sorry, I thought it was just the Family Types and not System Types related.
You would need to do this via Purge Unused but I get the hanging issue you get so this needs review.
I would only suggest then trying an add such as pyRevit or similar
Delete System-Family-Types in your Revit Project (youtube.com)
For reference I let the Purge Unused run with the spinning blue circle and after quite a while I got this. So just let it run i would suggest it may be linked to the Sofostik elements?
