IMPORT OR LINKED CAD FILE LEVEL
roethbrad
roethbrad
IMPORTED/LINKED Cad file into Revit and used XML file for placement. I attached my import options, (LINK CAD FORMATS_OPTIONS attachment). Also attached 2 other attachments showing what happened on linking in Revit. Levels are offset from data. When I move level to a elevation I need, it moves level correctly to where it should be and looks ok with toposolid, but then attachment level2 shows that the imported cad data moves like a offset from the toposolid.
Not sure if I have placed in the correct forum.
Any help would be appreciated in helping with changes to correct my issues.
"attachment level2 shows that the imported cad data moves like a offset from the toposolid"? Huh?
I'm not clear on what you are describing here, but moving the Linked DWG to where it should be in relationship to the Revit Project elements is correct.  Once positioned correctly in Revit, the coordinates of that position can be recorded back to the DWG via Shared Coordinates.
You are welcome to post your RVT and DWGs here for us to look at.  I think that would be best.
