Import from Revit to Autocad
beaudrygabrielle
beaudrygabrielle
Hello!
I export a Revit model into Autocad but now, my doors and furniture are in the same layers as Revit. When I export my Cad into PDF, my doors and furniture render in color even with BYLAYERS in properties. Is this something I can do on Autocad?
Thanks!
jvpantin2
It is a well known issue in the community, modifying DWG/DXF Export setup is quite a workaround, and hard to know for sure how it will works. Same with PDF files. Take a look to this post:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-export-DWG-...
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
syman2000
What plotstyle are you using in AutoCAD?
