Import FormIt into Revit "Disable Updater" Problem
I converted a "SketchUp" file to a "FormIt" file to a "AXM" file and I'm trying to make a "RVT" file but I ran into a problem when I was importing it. I put in the screencast not sure how to solve this issue.
ennujozlagam
@Anonymous hello, you can try to check it HERE and HERE. thanks
Hello nbaker13,
What do you want to do? DO you want to convert Sketchup file to REVIT file and want to keep all the materials intact?
CHeers!!
Prattusha
yes thats what I'd like to do
Sahay_R
Have you just tried to import / link your Sketchup file?
Insert >> Links CAD / Import CAD
And you will find Sketchup in the list of acceptable filetypes.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Hello nbaker13,
 You can import the sketchup file in the REVIT using the insert tab -> Link CAD-> File types option as sketchup. But you won't be able to get the materials right. It will be imported with just 1 layer. It's better to do the modelling in REVIT.
Prattusha.
