Hi!
I have an issue with exporting and importing back "actual supply airflow" and "actual exhaust airflow" information.
These parameters are put in a air terminal.
My question is if there is a way to import data from excel sheet to these air terminals?
Hi!
Solved by L.Maas. Go to Solution.
For these kind of jobs I use Dynamo. You only have to make sure that you convert it to the proper units.
Louis
Please mention Revit version, especially when uploading Revit files.
Louis
Ok thank you!
Im gonna take a look on it, i have never used dynamo before.
Ok thank you!
Well, there is a plugin from BIM One, its called Import Export Excel. This will do the job for you. Following is the link for that.
https://apps.autodesk.com/RVT/en/Detail/Index?id=6290726048826015851&appLang=en&os=Win64
