Import excel into Key Schedule
angelica.rodriguez.3d
I need to create a key schedule that will feed information into a room schedule.
They key schedule that I need in revit is pretty long with loads of columns and values. It there any way to import it without using Dynamo, please?
jay_colcombe
There is no OOTB solution unfortunately;
How to import Excel sheets into Revit
Jay Colcombe
Autodesk Certified Instructor
RDAOU
@angelica.rodriguez.3d
Dynamo would be my first choice irrespective if it would be the easy version of wrting parameter values from excel or the complex version with timely syncs. If you are interested in venturing into this world here is a link which would be useful for you to generate both the graph and the needed python scripts Synchronize Revit Key Schedules Using an Excel Master List
Other than Dynamo, you can use Pyrevit, BIM Link or DiRoots Sheet Link (they used to be free...Pyrevit is still for sure and you can download from Github) to link and sync Excel worksheet to Revit Schedules...see quick youtube below on how to use Sheet Link
arq_42
You have "Export/ Import Excel" from Mlabs. It's free too.
https://apps.autodesk.com/RVT/en/Detail/Index?id=4498090464200969540
I think diroots recently switched to freemium, although I don't know if it affects SheetLink tool.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
Hi, thanks for answering.
I use Mlabs for Excel, unfortunately, it doesn't allow importing or exporting to Key scheduled, only model schedules
arq_42
Check the version you have installed.
I think it's possible since 5.1 version, but with the "Schedule link (box)" button. It doesn't work with "Export to Excel."
