Hello all,
I have some details for doors in Autocad and I want to use them in Revit. I also want to be able to edit more these details in Revit.
What I did:
I imported CAD the details in Revit. All the details were all together in a 'Block' so I exploded it once.> The details were separated but in smaller blocks. (Each block contains multiple other components). In order to edit these components I exploded again but I lost some lines etc....
So this is not the best solution for me.
I tried also to make each detail a group but again in order to edit the group I need to explode it and I lose some lines...
What else can I do in order to be able to edit these details when I pass from AutoCAD to Revit?
Thank you in advance!
