Import CAD details and edit them
mairh_tsek
mairh_tsek
Hello all,
I have some details for doors in Autocad and I want to use them in Revit. I also want to be able to edit more these details in Revit.
What I did:
I imported CAD the details in Revit. All the details were all together in a 'Block' so I exploded it once.> The details were separated but in smaller blocks. (Each block contains multiple other components). In order to edit these components I exploded again but I lost some lines etc....
So this is not the best solution for me.
I tried also to make each detail a group but again in order to edit the group I need to explode it and I lose some lines...
What else can I do in order to be able to edit these details when I pass from AutoCAD to Revit?
Thank you in advance!
Ilic.Andrej
Explode everything in autocad before importing in Revit. Then explode in Revit.
Try this too. After you import to Revit, do full explode - not partial.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
mairh_tsek
The result was worst now..again I lost some lines..
kittugs143
1. Open your CAD details and change them to 0 layers then delete the Hatch pattern in the CAD file.Clean up your CAD file before importing into Revit (By this we can get single line type in Revit).
2. Then import your CAD file into Revit as mentioned in your comment some lines are missing -> Yes because in Revit minimum line length should be more than 1/32" if the line is less than 1/32" it will automatically delete those lines.
Manually we need to join the gaps.
Best regards,
G.Sivakrishna
Product Specialist - AEC
www.sivakrishna2013.weebly.com
If you find my post interesting, feel free to give a Like.
If it solves your problem, feel free to click Accept Solution.
mairh_tsek
Well it is impossible to join all of these lines in so many details.
So the only way to edit eack block is first to explode it, right?
Thank you for your time!
kittugs143
yes explode the blocks in CAD and mostly in some placed we cant even join the lines in Revit.
Go to manual method.
orelse if your detail is full set in AutoCAD try to link them in Revit then it works no need of rework in Revit again but usually no one prefers only at deadlines situations only.
RobDraw
Importing .dwgs has quite a few issues and it should be avoided. Lines less than 1/32" you've discovered. Text and leaders do not translate well or at all and that's just for starters.
Also, for each .dwg you get a set of line styles. Even if the same layers are used in every detail, you are going to get a set of line styles for each one. Best practice is to either recreate the details in Revit using any of a number of strategies or make sure to change all the entities to native Revit line styles and objects.
Rob
