Is there any way to add texture to parametric family of wall ?
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
Gelöst von Ilic.Andrej. Gehe zur Lösung
A wall is a system family, it has layers. Edit type, click "edit structure" and change layers. Every layer is associated with a material which has a surface and a cut pattern. Beside that, the material may have an appearance asset which allows you to load an image of the texture.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
By "texture", I assume you mean a material map?
You can add a "texture" in the Materials assigned to the compound layers of a wall.
Select the wall, under Properties>
For an in-place family, wall category--you can assign a material parameter to the wall, with a texture/ map assigned to it.
