Import button missing Enscape material library
amaniibasim
Message 1 of 9
amaniibasim
When I try to insert materials from the Enscape library, the IMPORT button is missing as the material editor window is too big  for my screen. I have tried hiding my taskbar in windows but that didn’t work. If someone can help me out that would be great.
Thank you
Replies (8)
Message 2 of 9
syman2000
The enscape forum suggest you up your resolution beyond 1280 x 720. Anything lower will obscure the import button.
https://forum.enscape3d.com/index.php?thread/20197-bug-importing-materials/
Message 3 of 9
ennujozlagam
https://forum.enscape3d.com/index.php?thread/22713-problem-whith-the-import-button-materiales/
Message 4 of 9
amaniibasim
How do I up the resolution through enscape?
Message 5 of 9
amaniibasim
Hi, I have checked this thread but I couldn’t really find the solution
Message 6 of 9
syman2000
To increase resolution, go to your display settings and set the display resolution
Message 7 of 9
amaniibasim
Thank you. My current resolution is set 1920 x 1080 which I believe is the recommended for enscape?
Message 8 of 9
amaniibasim
My resolution is also set to the highest it can’t go larger than 1920 x 1080
Message 9 of 9
syman2000
Usually 1920x1080 should work. Do you have zoom in screen or text set to 150%? Try to update the graphic card. Typically this will dictate what gets display on screen.
