Image in front of filled region in title block
PieterL_TM
PieterL_TM
Is there a way to have a raster image in front of a filled region in a title block.
It works in the family, but not once I load it into a project.
vitorbortoncello
Try placing the image last, after the filled region, to see if Revit prioritizes its display or create separate families for the filled region and image, and load them in the desired order.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
handjonathan
Hi @PieterL_TM
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
PieterL_TM
I'm sorry for saying this, but these kinds of comments are super annoying. I'm reading the suggestions, if anything solves my issue, I will accept this as the answer. If more info is asked, I will provide it.
