I made a generic model family and when i load the family in the project, the family automatically shows the volume in the properties.
Is there a way to turn off this automatically displayed volume?
I only want to show a specific calculated volume from the family.
Thx in advance.
Gelöst! Gehe zur Lösung
Gelöst von azad.Nanva. Gehe zur Lösung
Gelöst von vitorbortoncello. Gehe zur Lösung
You can find the family attached.
The "Volume" information is a Built-in paramter and Built-in parameters in Revit are default parameters that are hard-coded into the software and cannot be modified, they are read only.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Yes you can change the Generic model to Site and no need to see the true Volume:
