IFCWall in Revit, wrong consistent color?
I've a custom wall that I exported to IFC, then I open in Revit, the color is not showing correctly. Why?
I tested in Solibri, the color is correct.
Please help...
2016-09-28_19h08_19.png2016-09-28_19h09_24.png2016-09-28_19h10_10.png2016-09-28_19h10_44.png
Alfredo_Medina
Select the object that used to be a curtain wall, click Edit in Place, select one panel > Edit Type > Click on the name of the Material, and check the Graphics properties. It could be that the option for "Use graphic appearance" needs to be activated. That's what I can report after making a test about this.
The graphic appearance settings is correct.
It weird that when I change the IFC Class Name from IFCWall to IFCFurniture, the consistent color works correct. Is the Revit get details from IFCWall differently?
Alfredo_Medina
@Anonymous wrote:
...Does Revit get details from IFCWall differently?
I don't know that. IFC is another format, and several things get lost in the translation.
IFCWall colors works fine when I link IFC, but the color is wrong when I open the IFC File.
Why ?? It is the same IFC File.
