IFC shared coordinate issue
Message 1 of 1
In my Revit (2018) project, ARC, STR & MEP models shared its coordinates with same survey and project base point, however, when I export as IFC (2x3), it doesn't share the same coordinates. If I open IFC format of individual discipline model in Revit, it shows the same survey and project base point as defined in the Revit model.
Can you suggest a fix to bring the IFC format shares the same coordinate as like Revit?
Regards
Sundar
Replies (0)
